Cable / Connection query
Discussion in 'Cables & Switches' started by MJeeves, Aug 30, 2001.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Dear All,
    I am purchasing a Toshiba SD900E DVD Player and wanted to get THE BEST cable to connect it to my Pioneer Rear-Projection T.V. Unfortunately, the Pioneer doesn't have Component Inputs, but it does have RGB Scart and S-Video. Which is the best connection I can possibly get? S-Video? RGB? Also which cables do you recommend? I have heard and read really good things about the IXOS 126AV 21 Pin Scart to Scart cable for RGB connection. Does anyone else use this?
    Please let me know as I really want to squeeze the very best out of my new player.
    Thanks.
  2. Jase
    Jase
    Mar 16, 2001
    10,832
    United Kingdom
    +2,727
    RGB is the way to go. I did a back to back on my Toshiba dvd, SVHS v RGB, and RGB came out on top, better definition, to my eyes anyway.
    Cant comment personally on the IXOS cable but i´ve heard good things about it.
    cheers
