Cable connection advice needed
Discussion in 'Plasma TVs Forum' started by andy_mart, Feb 17, 2003.
  1. andy_mart
    andy_mart
    Hi Guys
    Someone out there must be able to help and am rather green to subject. I have just bought a Plasma screen and a Yamaha Surround amp and speaker package from HiSpek who gave me a fantastic price and worked to my budget but the advice given was somewhat out. Basically found out that Yamaha Amp only has composite video connectors.
    I have just bought a Panasonic Plasma TH-42PW5B which has Component connections, Composite (look like standard push fit audio connectors) and S-Video and Composite connections (again with look like standard push fit audio connectors.
    I have sussed out all audio connections to amp but it is the visual connections that are causing a lot of problems.
    I have the following equipment I need to connect:
    Panasonic TH-42PW5B Plasma
    JVS SVHS video recorder Scart only connection
    DVD Player with both Component and Scart RGB connections
    Grundig Sky box with RGB capable SCART
    Yamaha HITB45 Surround Amp this only has Composite Video connections in/out
    Having read the forum it would seem that Component connections are the way to go, so how do I connect both the Grundig Sky Digibox (Which is watched a majority of the time)which I believe to have only a RGB capable Scart connection and the DVD which has both Component and RGB capable Scart output. I dont want to resort to keep changing leads over manually at back of Plasma screen. I also want to be able to copy non-copyright DVDs from DVD player onto JVC Video recorder.
    I have been offered a Scart switcher which is RGB capable but will there be a loss of picture quality by using this.
    I am totally at a loss here and never had a problem when I had ordinary TV which had RGB enabled Scart socket, however with only Component and S-Video and composite connections.
    Many thanks
    Andy
  2. jmack
    jmack
    dvd to component on plasma
    sky rgb scart to svhs then either s-video into plasma
    or svhs ro s-video on plasma
    and sky rgb to converter to vga input on plasma
    all audio to amp
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,882
    The Borders
    +3,117
    andy_mart
    Plenty of options to play with and why not return the Yamaha if your not happy with it and its not got the features you asked for!
    Three quick questions:
    1. Do you intend to use a PC with your display?
    2. Is your DVD offering progressive scan on the Component outs?
    3. Does your Grundig box have a second SCART socket that offers RGB pass through.
    Best regards
    Joe
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Is that a current Yamaha? Mine was used to entertain the animals on Noah's b.... Ark, and has s-vid switching. Many modern amps do component switching as well as s-vid, you could do a good job with one of those, without touching the plasma remote, and leave the pc input free for x-box or PC gaming... you know you want to!
