Cable box to AV amp
Discussion in 'Satellite TV, Sky TV & FreeSat' started by yogi, Nov 12, 2004.
  1. yogi
    yogi
    Hi I wanted to know what the best way of connecting my cable box which does have an RGB scart outout to my pioneer AV amp which has component, Yu connections and S-video connections. I want the best possible picture but my amp does not have RGB scart.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,129
    Rainham Essex
    +2,392
    If you need to put the video through the receiver then you will need to convert the RGBs (scart) signal to YUV component. The best way to do this is with a converter from www.js-technology.com which I have used in the past and can highly recommend them. Although not cheap they do give excellent PQ.
    Mark.
