cable and interconnects
Discussion in 'Plasma TVs Forum' started by itcosthowmuch, Nov 23, 2003.
  1. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    I am thinking of purchasing 1)Pana PW42PHD6 2) Denon AVR 3803 3) Denon DVD 2900 4) Mordaunt Short Premier speaker system. If I was to need approx 40m of cable for speakers, how much should I be budgeting on for all of the necessary cable and interconnects I will need (mid-ranged....... otherwise think I would be pushing my luck :suicide: with her who should (but isn't!) be obeyed).
    Thanks for any advice anyone can give.
    M
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    10% of toatl budget is normall reconmendation. I would look at higher spec speakers with that setup have a listen to the infinity Orues speakers, muche better than premiere but more money!!!
    Bandridge Profigold are good mid range cables what else will be connected?? EG sky etc and do you want amp to switch audio and video????
  3. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    Hornydragon, I was also considering the Harmon Kardon & infinity package, which has HK AVR 507, DVD506 and oreus 7.1 in it. Haven't had a demo of the HK gear though......has anyone else? Sky/PS2 will also be connected and yes will need the amp to switch a & v.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Check out Paul (groundy) at www.scorpioncables.co.uk - he is a forum member and makes quality handmade cables pretty cheaply - well regarded on the forum and from personal experience the cables are great!!!
    Who knows, may do you a bundle price ;)
    JJ
