Cable and Banana Plug query
Discussion in 'Cables & Switches' started by oconnpad, Nov 29, 2004.
  1. oconnpad
    oconnpad
    Nov 29, 2004
    260
    +4
    Hi, i'm new to this site so firstly hi to everybody.
    My set-up is:
    I've a Pioneers AX5i receiver and my speakers are MA Silver 10i Centre and the rest are MS, 906 fronts, MS 903 surrounds & MS 902 surrounds back.
    I'm using Monitor Audio Pureflow speaker cable for the front 3 speakers and Audio Innovations Ultra Micro for the surround 4 speaker
    So finally my question is with gold plated connectors on the Receiver and the Speakers and i'm using silver speaker wire does it make a difference about gold or silver banana plugs?
    It's a toss up between €80 for silver plugs or €46 for gold plugs to do all my speakers, is it worth it would i hear any difference.
    Paddy
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Hi Paddy,
    I wouldn't spend more than £3.00 on any plugs or spades unless your kit costs tens of thousands of pounds!
    Here's something that might influence your decision:
    The internal wiring in your speakers is only cheap copper wire so whatever you use (unless you re-wire your speakers) will be lost by the time it reaches the speaker drivers.
    Get the cheapest connectors you can.
    www.cpc.co.uk would be a good place to start.
    HTH
  3. oconnpad
    oconnpad
    Nov 29, 2004
    260
    +4
