cable advice
Discussion in 'Cables & Switches' started by TEKNICOLOURFOX, Sep 12, 2007.
  1. TEKNICOLOURFOX
    TEKNICOLOURFOX
    May 23, 2007
    2,052
    48
    doncaster
    +63
    Hiya,
    i need couple of decent leads...
    scart to scart 1.5m
    component 1.5m
    but on a tight budget, any advice would be much appreciated!
    cheers
  2. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    With regards to the Scart it depends on how decent you want.
    If you want a good priced premium brand scart then this one from Thor is a bargain IMHO.
    Thor Scart Audio & Video Cable - 1.5m
    However If this is out of your pricerange then I personally have found the cables from Kenable to be fantastic value for money and performers.
    Pure Scart Cable - FLAT - Metal - OFC - 1.5m
    You wont find a decent Scart cable cheaper than this.
  3. TEKNICOLOURFOX
    TEKNICOLOURFOX
    May 23, 2007
    2,052
    48
    doncaster
    +63
    cheers anthony1uk, i found the thor cable for £10 at bandq so got that lot better pic than the old cheapie cable
