Cabinet controler
Discussion in 'Home Cinema Control & Remote Controls' started by technique786, Jan 5, 2012.
  1. technique786
    technique786
    Dec 20, 2011
    311
    +8
    Hi guys,
    Looking for a very discreet way to control things like my av receiver, virgin box and a media centre inside my tv cabinet. I want something almost invisible but sensitive enough so we never struggle with it.
  2. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    if you get the harmony remote with RF capability then it can be completely invisible as it sends RF signal through the cabinet and then converts that to IR inside the cupboard to blast it to your components
