CA Minx 11/21 and 3rd party sub
Discussion in 'Home Cinema Speakers' started by lex524, Feb 26, 2013.
  1. lex524
    lex524
    May 16, 2003
    131
    Brentwood, Essex
    I am seriously considering the Minx 21/11 setup for my lounge. However, I already have an MJ acoustics Reference 100 sub (Mk1). Its a very nice sub, and I would like to keep it if possible.
    I would like to use it with the minx but not sure how well it will work. Its range is 13hz to 120hz. This exactly matches up with the Minx... (which go down to 120Hz)
    Has anyone used a different sub with the Minx (with crossover set at 120Hz)? Anyone any idea if this would work?
    Planning on running them from a marantz 1603, by the way
    Alex
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    Any sub will work with any speakers so no issues with your proposal.
  3. lex524
    lex524
    May 16, 2003
    131
    Brentwood, Essex
    I realize it will technically work, but will it sound good? I always thought it was best to have some "overlap" (i.e. set crossover at something like 140Hz).
    Its unlikely it would be easy for me to test this so interested to know how people are runnign their Minx's!
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    There will be some overlap since the minx will roll off below 120Hz and the sub will roll off above this as well.
  5. lex524
    lex524
    May 16, 2003
    131
    Brentwood, Essex
    Ah ok hadn't realised that - thanks!
