Ca Dvd79
Discussion in 'Blu-ray & DVD Players & Recorders' started by masher, Jul 5, 2005.
  1. masher
    masher
    Anyone tried one of these?
    Have an Azur540D which I really like, but would like the digital output of the DVD79 if it is better than the component of the 540D.
    Thoughts... :rolleyes:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I've heard problems about lip sync with DVI. I had one but never got as far as DVI, the component PQ wasn't great and didn't have prog scan (prog scan only on DVI). I decided to swap it for a Pio 575. It was a nicely built machine, menus were a bit naff though...PJ :)
  3. Chrper
    Chrper
    Feb 10, 2005
    90
    I had a DV79 and it did have the Lipsync problem on DVI output, Picture quality was great but as the lipsync was not all the time I couldnt even fix it with an audio delay through the amp!!
    So it went back and I too got a Pioneer 575 which has great PQ and non of the above problems, Oh and its cheaper!!
    Hope this helps
    Chris
  4. skourip
    skourip
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
  6. destine1
    destine1
    I've been tracking the CA forum (http://www.cambridgeaudio.com/forum...rmware+Problems) for a couple of months now. Then today, I went to check on the status of the firmware update eluded to by CA's own CEO (just ask skourip about this) that would be available soon after Oct. 24, but the forum seems to be removed from CA's website. I don't know if they did this for maintenance reason, or this is a pathetic attempt to silence the nonexistent firmware upgrade. skourip, can you please give us an update on the DVD79 firmware upgrade?
  7. chrhall
    chrhall
    Yup, that would be nice skourip. I'm a bit amazed that the forums are down, especially because they were quite good.
  8. skourip
    skourip
    Hi guys. I have also noticed that the forums are down but the reason is not the DVD79. I have now received the new version of the firmware and I am in the process of evaluating it. Its does seem to be an improvement over the previous version but I will post my findings once I have completed all the tests.
