Question CA CXN (V2) or CA AZUR 851N?
Legzr1
Apparently the 851N is being discontinued and is available on CA eBay shop at £800 so any ‘additional cost’ may not be as ‘additional’ as you thought!
If there’s a chance of you using Roon in the future, the CXN may be the one to go for as CA are looking into a firmware update to allow this. This will not be an option for the 851N and has quite a few owners rather annoyed. Before the Edge series was released the 851 range was their top tier product so the decision seems strange (I understand the 851and CXN use differing OS and hardware making it all but impossible to update the 851N for Roon).
Personally, and subjectively, I much prefer the 851N to the CXN. It looks and feels a better quality product in use and sounds more mature, more ‘grown up’ and gives me a sound I’m very happy with. There’s a clarity to the midrange and texture to the bass that always seemed a little lacking with the CXN (and previously the SM6). My room, my equipment, my ears etc etc and I get that others might disagree but I actually did pay £600 to change to the 851N - no regrets here.
I’m even getting Tidal Masters now using an app suggested on this forum (Mconnect) which does the first ‘unfold’ using the iPad processor and sends (up to, depending on source file) 24/96 to the 851N with excellent results.
At the end of the day, your original question is difficult to answer simply because ‘worth’ is so subjective. If you have £601 until pay day and the car needs tyres and a service then no, it’s not worth it. On the other hand, getting a new 851N for £800 (if still available - it was a few weeks ago I spotted mention of it) then the difference in cost is negligible and I’d suggest going for it. The inbuilt DAC and analogue sections are a step above in my opinion and the unit sounds great.
Best of luck with it and don’t forget to update the thread with what you decide.
Fergal82
Can a cxn or 851n be connected straight into an AVR or should it be connected to an integrated amp / power amp?
Adamgbiggs
They can be connected to any amp/AVR with RCA or digital inputs.
Adam.
Adamgbiggs
I take it you’re relying on how good (or bad) the AVR sounds for music if you did connect that way
Most recent AVRs can stream music like the CXN can, sound wise it’s really up to the end user to determine if it’s worth it or not.
Adam.
Legzr1
I’m probably the wrong person to ask having turned my back on surround sound in favour of stereo only but, for music at least, dedicated stereo for me. I’ve tried good Marantz, Denon and Krell processors but they’ve always sounded compromised in stereo compared to a good 2-channel set up.
Using an 851N into a midrange AV amp would work but it’s capable of so much more.
Using it to output digital into an AV amp would be a travesty and an absolute waste in my opinion.
Adamgbiggs
I agree with this, I had a Denon X4200 AV amp and it just didn’t sing with stereo, no matter what I did with it music just didn’t sound great, disabled all the video processing etc, still nothing, in fact I originally replaced it with a Denon PMA720AE £200 stereo amp and it absolutely destroyed the £1,100 AVR with music, so I got rid and got a cheap AVR for movies and a decent stereo setup, pure bliss now.
Adam.
rocketride
Was wondering what peoples thoughts are on this.
Does the 851N justify the additional cost (£600) over the CXN??
Yes it does.
Azur 851N is much better sounding unit. Solid build and powerful sound.
Software upgradeable so now you can use Stream Magic app.
ABC*
I've got the 851N and really impressed with it, using it in pre-amp mode with a pair of Xindak 8800mnu mono block power amps.
MartinH32
hauxon
Old thread but UPDATE! The 851N now has Roon integration through firmware update.
See:
kartdriver8
I have a desired music outcome and I had some solutions. Here is what I went with. Hoping this will help others.
Situation:
I have a vast iTunes music library of purchased and ripped music. I went from a 20 year old AVR to a newer AVR that can stream music and such.
Desired Outcome:
I want the best quality of music to come from my iTunes library and have the option to stream Tidal or Qobuz with the solution.
Solutions:
Either stream directly to the AVR and take advantage of the internet streaming apps that are built in. The other items I looked at are Cambridge AVN and 851N. Other solutions I looked at are Roon and others.
Verdict and WHY:
I went with a Cambridge Azur 851N. The reason is to clean up my existing music library and just stream all my music through it. Brand new they are running $1499. I picked up mine from ebay for $1100. If you are patient, you can get a good one for between $1000 and $1250. Looking at the alternatives was going to be from $500 for a small server to $1000 for another brand streamer. In the end, was not adding up to what I would potentially get with the Azur 851N. In the future, I can layer Roon or other tech to expand its capabilities.
I hope this helps.
kartdriver8
Rajeev Kale
Hello
I want to know whether you can do Home theatre bypass with Azur 851 and use for both music and HT
I will be using Azur 851 power amplifier for stereo and Denon 7200 W for HT
My front L & R will be common for both the set ups
please advise
Marve77
I was faced with the exact same dilemma, opted for the 851, got a refurbished one from CA on ebay for £900 I think, couldn't tell it wasn't brand new. Although the cxn does get some very good reviews, don't regret my choice very happy with it. Would be nice if bluetooth was built in but I mainly play from an attached hd so not really an issue. Only thing could possibly be that I'm not sure if the dongle for bluetooth does aptxHD or just aptx, sounds good whatever it is though.
larkone
AptX though this only works if the sending device also supports AptX otherwise it is SBC
Michael Bayleaf
I also opted for the 851N, am very happy with the decision. (Think StreamMagic isn’t the best streaming app but that’s a topic for another day....)
Marve77
Yeah, it's a wee bit strange. When streaming from my phone, if i'm streaming flac files stored on it using the player the 851 only shows the device name but if i'm playing Amazon Music it shows the device name with 48khz aptx below, so i'm assuming for some reason it's only using sbc for files stored on the phone.
mtenga
RS has a flash sale on the 851N to £999 this weekend so I bought one. If the app is rubbish, like on my Node 2i, I might just take the pain and Roon up.
Cebolla
In which case it may be worth the intellectual (rather than monetary) pain of trying to get the 851N to work with the free Logitech Media Server and relevant LMS plugins before you do - to get something like:
1596065521763-png.1342363
1596065571509-png.1342364
1596065741049-png.1342365
Latest News
BBC licence fee to be scrapped in 2027
  • By Andy Bassett
  • Published
What's new on Netflix UK for February 2022
  • By Andy Bassett
  • Published
iFi Audio launches ZEN One Signature DAC
  • By Andy Bassett
  • Published
Rotel announces MKII versions of A12, CD14 and RCD-1572 devices
  • By Andy Bassett
  • Published
Bang & Olufsen software update expands speaker connectivity
  • By Andy Bassett
  • Published
