CA 540R remote a bit useless
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Marvt74, Sep 18, 2005.
  1. Marvt74
    Marvt74
    Feb 13, 2005
    593
    Manchester
    +16
    Anyone else found problems with the remote that comes with the Cambridge Audio 540R cd player?
    Mine never seems to do anything unless you wave it around pressing buttons every five seconds and its getting a little annoying
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,258
    63
    Perth, Western Australia (Originally Ireland)
    +228
    What exact product are you referring to? The 540R AV Receiver or the 540C CD Player?
    Generally these unbits are very reliable but you may have a dud remote. Of course check the batteries arent wasting...
  3. Marvt74
    Marvt74
    Feb 13, 2005
    593
    Manchester
    +16
    Ah its the cd player i got confused with the model number.
    I've tried new batteris but its been the same since new
  4. b!lly
    b!lly
    yes i get the same prob with both the 540r av and also the 540c cdp,just dont want to work unless u aim it like u going for teh target,,,and these are both brand new pieces of equipment....
  5. cribeiro
    cribeiro
    Nov 2, 2002
    2,797
    A Spaniard in Germany
    +307
    Hi there!
    I got 3 different remote controls from my dealer until I got a "good" one. Same problems you describe. The new models should have that sorted out... Try to get it swapped while still under warranty...
    Otherwise, nice, beautiful and good sounding...
    Regards,
    Alberto
