C905 battery life?
Discussion in 'Mobile Phones Forum' started by englewood, Feb 5, 2009.
Tags:
  1. englewood
    englewood
    Sep 6, 2006
    28
    3
    How is peoples battery life on there c905?
    Mine last 2 days only a couple of calls and some texts, some wap surfing but battery dies fast.
    Should i buy a new battery or is the phone the problem?
  2. paulsmith27
    paulsmith27
    Feb 6, 2009
    4
  3. englewood
    englewood
    Sep 6, 2006
    28
    3
    Yeah i think i will purchase another battery see how it goes!.
  4. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    I am a bit concerned about this battery, It's the same as in the wifes W580i and it's very poor.
  5. dj_padd
    dj_padd
    Dec 27, 2008
    1,516
    Mid Wales
    +255
    Mine will last about 4 days before it needs a charge but i usually charge it every other night
  6. Ishtiaq
    Ishtiaq
    May 3, 2009
    Keighley
    Sadly, I have one of these truly awful phones. I won't bang on about the phone having the crappiest keypad of any phone I have owned, but I do recognise the problem of the short battery life. My phone suffers from this whenever I have switched on the wi-fi. It seems that when I switch it off again, even though the phone tells me the wi-fi is off, it isn't! I have found the only answer is to do a master reset. If you do this remember, it deletes EVERYTHING THAT IS IN YOUR PHONE. I always put an old sim in the phone and remove the memory card. Though whether everything on the sim and card would be wiped I do not know. I prefer not to take the risk. Hope this helps... Ishy
  7. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    I use GPS and about 45 minutes worth takes 35% out the battery.
    Normal use however I get 4 or 5 days.
    At the end of the day we have 4 SE chargers so I keep one at work so charging isn't an issue.
  8. sbaddison
    sbaddison
    Oct 2, 2005
    359
    Warwickshire, UK
    +6
    I use WAP a lot on mine and battery life is really poor!!
  9. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    I have the same problem now - used to last a week on a full charge, now less than 24 hours. Anyone found out what it is?
  10. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Master reset without deleting personal settings seems to have done the trick - wish me luck with the firmware upgrade next! Still an excellent phone, plus I now have a spare battery for it!
