Quantcast
C7P sound volume display won't go away- Help
bxtq
Hi All,
Our C7P has had this problem from the beginning (approx. 2 years old) but it's intermittent. Sometimes the bar is on, sometimes it's off. Once it's on, it stays on. LG suggested a factory reset but I'm worried about losing the picture calibration I paid for. Is there any way to fix this? Any help would be appreciated. Thanks!!
JayCee
Have you tried removing the batteries from the remote?
A stuck-down button on the remote or on the set itself can cause that.
