C770 Subwoofer
Discussion in 'Subwoofers' started by billsy, Jan 2, 2003.
  1. billsy
    billsy
    Jan 2, 2003
    5
    UK
    I just purchased a Sony DAV-C770 home cinema setup, it’s a nice system but the passive sub that came with it isn’t up to much. My previous setup included a Yamaha YST-SW45 active sub, which kicked ass. Is there a way I can connect the high level output from the C770 to the low level input of the SW45? If not is there a passive sub that will come close to the Yamaha one? The feed to the sub is 100w
    Billsy
