C31 Preamp - How to get Volume graphic on LCD?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by rajkat, Nov 1, 2005.
Tags:
  1. rajkat
    rajkat
    In all the product photos of the C31 preamp it shows the volume level as a graphic on the LCD display (in some reviews it mentions this also).
    In the manual there is no mention of it though - can't seem to find it myself either by playing ....any ideas?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,578
    Edinburgh
    +1,269
    If you look at page 8 of your manual it will show you how to change the volume display, if you select 'Reference' it will display the volume in -dB steps.
  3. rajkat
    rajkat
    Thanks Crusty,
    but I'm actually trying to get the bar-graphic volume display (as seen in the literature).
    Reference level (and the others) still give a numerical display.
  4. ruben20
    ruben20
    Jan 28, 2004
    76
    Netherlands
    +3
    On my A32 I can change it with to following commands:
    Press "Sel" 4 times. The display reads "custom settings"
    Press "+" two times. The display reads "Volume display mode"
    Press "Sel" again to enter this mode.
    Press "+ or -" to change it to graphic.
    Press "enter" two times to enter the menu.
    This should work if they haven't changed the menu.
    edit: maybe it only works on "standard" or "fine" level of volume resolution
  5. ar1234
    ar1234
    Nov 2, 2005
    7
    I searched for this too, and found that this is not available anymore on the C31.
  6. rajkat
    rajkat
    Thanks for your help anyway. Still odd it's shown in the photo's though.
