C-Sync on Sharp Z9/10/12000 - does it work ?
Discussion in 'Projectors, Screens & Video Processors' started by tbguk2, Feb 21, 2005.
  1. tbguk2
    tbguk2
    Nov 24, 2004
    46
    I have a Sharp Z9000 Projector - and can I get an RGB from the SKy box ? No !!
    Now, on the back panel we have 5 phonos - selectable as Component or RGB via the menus.
    One of these is "C-Sync". So you'd think that feeding a composite signal from the Sky box would provide the sync. Seems not. If I take the Composite from the Sky and place it into the Green input, I DO get a picture (albeit with no green).
    So, has anyone here got one of thise family of projectors ? How have you got an RGB signal in (without converters). Seems cracy the CSync is listed there but doesnt work ?
    Appreciate any bright ideas.
    Regards
    G.
  2. tbguk2
    tbguk2
    Nov 24, 2004
    46
    No one here got a Sharp Z9/10/12k ?
  3. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Well, RGB doesn't have a sync level, so you are going to need something that puts sync on the green line.
    I would suggest (As I personally have one for a Z200 and my Sky+ box) a Syncblaster cable. They are not cheap, but neither was your projector.
    If it doesn't work or you are not happy with the resulting picture, I think they will still offer the option to take it back.
    Hope it's of help.
