That's a hard question to answer. If it's a DIY-style plug, then it should be possible to take it apart and let it dry out properly. Sealed, molded plugs should let in less water but they will still have a removable fuse carrier/compartment that might allow water to get into the plug and this water may not be able to get back out very easily.
How wet did the plug get ? If it's an original, factory-fitted plug that you can't take apart and it got a good soaking, I would probably cut it off and fit a new one.
