C- Band help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Mattk, Nov 9, 2003.
  1. Mattk
    Mattk
    Just after some help for setting up a C-Band setup. I have an Echostar AD-300IP. I have a 1.3 metre prime focus solid steel dish so would I be able to cobble together a setup with a C-band LNB out of this or would I have to get a proper C-band dish?
    Matt.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,239
    Manchester
    +747
    I assume you mean AD3000IP (not "300".
    You could do it but you won't capture much with a dish that small :-(
    A loook at various satellites with C-band and European beams on Lyngsat (www.lyngsat.com) will give you an idea. Click on the mentioned "beams" to see the footprint/signal strength.
    Chris Muriel, Manchester.
  3. Mattk
    Mattk
    I'm after a music channel on Arabsat 26.E on C-band it should be receiveable in the UK, I was just wondering what equipment I would need.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,239
    Manchester
    +747
