BW Speakers Setup - 600 Series
Discussion in 'Home Cinema Speakers' started by Vinesh, Oct 23, 2004.
  1. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Is this is a good setup?
    Fronts - 601
    Rears - 600
    Centre - LCR60
    I might be buying the above to replace my morduant short setup..
    Replacing MS908, 905c and 903.
    Will there be a improvement with the sound? I know I need to demo the BW first.
    Thanks in advance.
  2. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    up
  3. recruit
    recruit
    I presume you mean the S3 B&W speakers, anyway i would say they are ok but you would need to add a sub as you will be limited with the Bass from the 601's.
    I have not heard any MS speakers so could not give an opinion if they are any better than what you already have.
    John :)
  4. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    There the ones - 600 s3
    I already have a sub :)
  5. SKA.face
    SKA.face
    I don't think you can wrong with the 600 series B&W,a hell of a lot of sound for the price,tweeter a touch metallic,but a nice clean midrage,tuneful and enjoyable sound,sound great for AV too.
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    I would suggest looking at matching a better sub with those speakers, the B&W ASW675 would be a good match.
