Bw mt60 or monitor audio bronze 5.1
Discussion in 'What Speakers Should I Buy?' started by Poorak, Apr 28, 2018.
  1. Poorak
    Poorak
    Apr 28, 2018
    19
    manchester
    Hi.
    Which one would you recommend from these?
    Bw mt60 or the monitor audio bronze 5 5.1 ?
    Thinking of getting the denon 2400
    Room is 14m long and about 4m wide with 2.1m ceiling height
  2. Member 769353
    Member 769353
    Previously davidf
    Nov 2, 2016
    1,399
    116
    birmingham
    +752
    Larger rooms like that ideally need larger speakers to fill them better. You can use the smaller speakers, but you'll have to use a couple of subs for larger spaces.
  3. Poorak
    Poorak
    Apr 28, 2018
    19
    manchester
    I liked the sound of the mt60 package when I heard in shop. Not heard the bronze 5 yet but read good reviews. The shop guy said the m1s will be really good for the room.
    Will take pic of room later and upload
  4. Member 769353
    Member 769353
    Previously davidf
    Nov 2, 2016
    1,399
    116
    birmingham
    +752
    Small speakers in large rooms tend to lack bass presence, particularly at lower volumes - larger speakers tend to naturally be able to fill larger rooms easier.
