BUZZZZZ!!!!! I.C.E Interference HELP!!!!
Discussion in 'Video Streaming Boxes & Services' started by Robotochan, Mar 16, 2006.
  1. Robotochan
    Robotochan
    Damn, just wired up three halfords Ripspeed amps to my car, one is powering 6*9's on the shelf the other two are poweing two 15" subs each, but i'm gettin a clickin/buzz at low volume which increases with engine revs! i had the lot running the +12v in series and seperate earth's to the chassis, oh yeah i thought the buzz was only coming from the 6*9's but that was because they were set to high pass, when i checked the subs on high pass the interference was there as well, so last night i set all the amps in parallel with splitter boxes did the same with the earth which is now being run back to the battery (through the window at the mo:D ) and not to the chassis, now instead of being an intolerable clicking its very low engine rev noise instead, i now you can get noise filters for house hold hi-fi use but is there an incar option and/or is this even the prob? :lease:
    [​IMG]
  2. The TV Engineer
    The TV Engineer
    Mar 2, 2006
    131
    +16
    Thats a suppressor fault on your alternator..
    Replace the suppressor, it bolts onto the back, very easy to do.
    There are RCA filters available as well.. Autoleads product code PC8-101
    Hope that helps :)
  3. Layne RIP
    Layne RIP
    Sep 22, 2005
    710
    Chilliwack
    +11
    Did you by chance run the RCA leads and the power leads down the same side of the car?
  4. Robotochan
    Robotochan
  5. eL-ZilCHo!
    eL-ZilCHo!
    Oct 18, 2005
    769
    All on my own
    +44
    how've you earthed yor amps? if the earth is a bit dodgy that can cause a hum. make sure where the earth point is is clean and is bare metal, rather than painted. Failing that i'm afraid its a case of taking different parts out of the system, one at a time to determine whats causing the problem. It could be anything. but i'd look at the earth, making sure its a clean connection. If you've already done that then i'm really not sure
  6. Robotochan
    Robotochan
    i did have the earths running seperatley to the chassis, now there running in parallel to a splitter box thats runnin a line back to the battery
