Buzzing
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bryce Curdy, Nov 22, 2004.
  1. Bryce Curdy
    Bryce Curdy
    I have one of the original Sky+ Pace boxes, now around 2 and a half years old. It has a very annoying buzzing sound, even when turned off. The only way of getting rid of it is to unplug the mains lead. I suspect it's been there from the start but is getting worse. I may be more fussy now that I've got a full home cinema kit.
    Had a quick look on here but didn't find anything directly related, although there was a reference to the hard drives of the early decoders being noisy. It doesn't sound like a fan, although I do have a video recorder sitting on top of the box. How crucial is ventilation for Sky +?
    Any comments gratefully received.
  2. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    If nothing else you could try swopping the two round so the sky box sits on the top of the video recorder!
  3. Bryce Curdy
    Bryce Curdy
    Thanks David. I do mean to try that. Because of the weight of the equipment on the stand, it's probably at least a half hour job involving lots of bad language! Anyone else know anything about this?
  4. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    One other thing you COULD try is to replace the mains lead on it. I of course take no responsibilty if it then blows up :) :eek: :p
