Buzzing power supplies in plasmas
Discussion in 'Plasma TVs' started by StooMonster, Mar 27, 2003.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Reading though some of these threads I've noticed that a couple of people have had their plasmas replaced but still get a buzzing noise from the PSU.
    Rather than the screen, could it be an environmental factor that causes this? i.e. Could this be caused by "dirty" mains supply?
    My reasoning is that PSUs in amplifiers can buzz because of quality of mains supply (apparently); one of mine buzzes in the evening but not during the day or late at night. I've read this problem is caused by mains quality; although it could be marketing propaganda from people trying to get me to buy their snake oil products.
    StooMonster
  2. ncpl
    ncpl
    Jan 21, 2003
    348
    Surrey
    Stoo,
    There may be something in it, especially if you have experience of a PSU misbehaving at different times.
    If you read the blurbs from RAndrews etc, then dirty mains is likely to have various effects. I certainly have noticed sonic improvements in several systems (my own included) having installed various 'snake oil' products.
    It would be interesting to see if the more technically minded forum members have any experience or theories on this.
    Dr JS, you seem like a clever chap...whad'ya know ?
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Read the Russ Andrews, Ben Duncan, et al literature and decided to replace all my mains cables and distribution blocks; but with high quality DIY kit. (Some posts in DIY forum about ChrisVH mains leads.)
    It seems possible that environment is a factor if PSU continues to buzz in an installation, after you've had the screen replaced. Either that or you've been really unlucky and got two, or three, faulty PSUs in a row.
    Guess a test would be to either try some mains filtering (or new power lead), or plug the screen at another location and see if it buzzes there too.
    StooMonster
  4. nathan_silly
    nathan_silly
    High voltage creates buzzing, so it might not be a cheap power supply, just in the way it works.
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    True, but wouldn't plasma PSU buzz for all owners of a particular model, rather than some people?
    Hence my thought that it may be an environmental issue rather than a design issue.
    StooMonster
