Buzzing noise
Discussion in 'Subwoofers' started by Ferg 36, Nov 27, 2004.
  1. Ferg 36
    Ferg 36
    Nov 14, 2004
    3
    I've just purchased the acoustic solutions DS633 home cinema kit. When I set it up I'm getting a buzzing/humming noise from the subwoofer.
    It's not noticeable when the volume is loud but is very noticeable when there is a lull in the volume.
    Can any one advise what the problem is. Thanks in advance
  2. MillionDollar
    MillionDollar
    Nov 13, 2004
    55
    I'm having the same problem.
    I have just bought Mission M30 Cinema Package with a Denon AV 1905.
    My Sub is making a humming sound when it is on. You can hear it when it is in use but when the sound is off or when I have turned the AV amp off I can hear the humming sound. I have connected it with a IXOS subwooffer lead in the AV amp. It is meant to be using (LFE). So it is mean to turn itself off when not in use but the green light just stays on and you can hear the humming.
    Is this normal?? :confused:
