Buzzing noise Toshiba 32 inches
Discussion in 'Televisions' started by hanna256, Jun 8, 2004.
  1. hanna256
    hanna256
    I have a 32 inches flat screen Toshiba (32AF43) that is about 6 months old. When the TV is on for about 3 to 4 hours, a loud buzzing noise (relatively high frequency) starts coming from the back of the TV. The noise level stays the same wether the TV is muted or if the volume is cranked up. I am using a Satellite receiver, changing the channel on the receiver sometimes fixes the problem sometimes it doesn't.
    Any help will be appreciated.
