Buzzing from Speakers when Sky Search/Scan Banner Visible
Discussion in 'LCD & LED LCD TVs Forum' started by dvd.collector, Jun 6, 2005.
Tags:
  1. dvd.collector
    dvd.collector
    Mar 28, 2005
    46
    +6
    Hi all,
    Having swapped from the Sonix to a Sharp GA5, I've noticed that the Sharp is giving a buzzing sound from the speakers whenever (for example) the sky search & scan banner is on screen. The same effect happens on Sky news when the ticker bar is showing.
    Has anyone else experienced this? I'm using an IXOS scart cable connected in RGB mode from the sky box.
    I know the Sonix did not do this with exactly the same setup & cables I have now, so perhaps its a fault with the Sharp?
  2. Rob1698
    Rob1698
    Are you sure you are really viewing in RGB?
    This sounds more like something that could happen when using a composite signal.
