Buzzing from FS2 Subwoofer
Discussion in 'Subwoofers' started by gedclink, Apr 22, 2002.
  1. gedclink
    gedclink
    Hi folks...
    Got the mission FS2 set over a year ago..It came with the enclosed subwoofer...
    Only recently I've noticed that the Sub appears to be making a weird noise - almost equivalent to a low level " buzz "..
    This is most noticeable when the amp is turned down low / muted or indeed when I switch off the television set / cable box.
    The sub is connected to a Toshiba amp via the supplied umbilical leads. The sub has it's own power switch on the front of it.
    It will eventually stop buzzing about 10 minutes when the following occurs
    1) The amplifier has been off for about 10 minutes.
    2) The power switch on the front of the sub is switched off then on.
    What is happening...Any clues or more info needed
    Thanks in anticipation
  2. MartinN
    MartinN
    Mar 23, 2001
    60
    +12
    I've got the same problem, don't get your hopes up! Although in my case the hiss never goes away - until the sub goes into standby mode, or is turned off.
    I was told by the shop that all sub woofers suffer from some sort of hiss (speaker & built in amp being too close to each other).
    I've tried a few things, making sure the amp is earthed ok, but I get the hiss even if the sub isn't connected to the the amp.
    I hope you find an answer!
    Martin
  3. gedclink
    gedclink
    Mmmh..
    Thanks Martin...Need to try and sit further away from it.
    I hadn't really noticed it until recently when I was farting about with settings so I'll need to revisit them..
    When the Sub goes into standby it disappears but switching the sub on and off also cures it until it receives a signal from the amp...
    Is switching it on & off putting it into standby until the amp input kicks in?
