Buying/Setting up COMPLETE system (around the 435XDE) ...Help please!?
Discussion in 'Plasma TVs' started by Xstyle, Nov 22, 2004.
  1. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    My 435XDE has already been ordered... and should be with me in the next dispatch from Pioneer. ...2 or 3 weeks?
    I also am in a quandry over the dvd player and the amp ... (thinking of around £800 each or thereabouts) and the speakers!
    Want everything wall mounted, and the media box, dvd player, amp, ps2, sky+ box all housed in the wall cut-out.
    The front speakers would also go into the wall.
    The rear speakers would be wall mounted.
    ANY IDEAS on what would sound really good together, AND have major WAF!!!???
    How would all these connect?? into what sockets and what additional cabling do I need please?
    Can I run everything off of one remote control ... like a Harmony??
    (I would prefer to have as few remotes as possible!)
    Any advice would be greatly appreciated!
    Plan of my room BTW:
    ___________________________
    I.................Garage.................I
    I...........................................I
    I..Internal Door...........................I
    _ _ _ _______________________I _ _ _
    I.................Plasma...................Stairs I
    I...................................................I
    I...................................................I__________
    I....................................................................I
    I..Corner Suite....................................Dining...........I
    I..Sofa Along Here................................Table...........I
    I___________________________________________I
    <<<---------- Width 262" or 667cm ----------->>>
  2. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    I have just come across these speakers:
    http://www.artcoustic.com/products.htm
    The Artcoustic Multi can be used as centre and left and right... and looks awesome!
    but it is £1300!
    The Artcoustic Diablo's can used as rears ... and are £1000 for the pair.
    BUT the benefit I like with this is that you can put your own picture on them at £80 each! ...removes the need for any other artwork or whatever on your walls!
    (Ouch!!! ...when you write it down you can see how much speakers alone are costing!)
    Hmmmm...........
    Do I need front L and R, or will the Artcoustic Multi just do?
    (and pair of Diablo's at rear)
    whats your thoughts?
