buying my first printer
Discussion in 'Computer Peripherals & Consumables' started by gino_76ph, Sep 21, 2007.
  1. gino_76ph
    gino_76ph
    Aug 10, 2007
    574
    hiya. im looking for a printer. i will generally use it home. i have several criterias:
    1. ill be mostly using it for printing out offline Word/Open Office documents, CVs and the occasional photos on a glossy paper (from a digital camera's memory stick or from my PC) and online emails and docu's.
    2. must be compatible with most memory cards and memory sticks (like pro duo, sd, xd, etc.)
    3. not necessarily bluetooth but atleast an optional bluetooth adaptor
    4. cheap and easy to replace (and reuse/refill) ink cartridge
    5. can also scan at the same time
    now, would you recommend an "All-in-one" printer or a standard home printer? what make? pls help.
  2. Caralfa
    Caralfa
    Depends on how much you want to pay, or can afford, and to what quality and size you want to print your photos at. Once you have decided that then it's probably :rolleyes: how long is apiece of string?
  3. tricky0001979
    tricky0001979
    Aug 15, 2007
    253
    +34
    Try a Lexmark X6570 All-in-One Wireless Printer with Fax. from argos for £129.99
  4. Caralfa
    Caralfa
    That price is too high. only £110.45 from eBuyer including free delivery.
    But how big are the cartridges and how much are they? Lexmark is known as being expensive for ink and cheap printers! :(
  5. gino_76ph
    gino_76ph
    Aug 10, 2007
    574
    im looking at a budget of up to £100 only. im not exactly looking for those "All-in-one" printers coz i heard those inkjet ones have higher dpi's. i need your top two makes on this one please. (and never mind the bluetooth thing. as long as it's picturebridge compatible and it's USB 2.0 so you can connect your digtal cam)
  6. RyanK
    RyanK
    Sep 20, 2005
    1,104
    London
    +38
    i'm going for the X6570.
    Got a X6150 and VERy happy with it. Shame it won't work with a MAC:(
