Buying JVC GR-DVP3 - or should I get a Sony DCR-PC120?!? :-(
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by WebReaper, Jul 17, 2002.
  1. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    Jeez, this is so confusing!
    Just when I'd settled on the fact that I was going to buy a JVC GR-DVP7, I find a whole load of opions (on another BBS) from some people with JVCs saying that if they were buying again they'd get a Sony PC120.
    Size is very important, but I'd not realised that the Sony isn't much bigger than the JVC (~1cm wider and deeper, but 1cm shorter too). So it's certainly small enough.
    Judging by the prices I've found, the Sony's going to come in at about £100 more than the JVC, but it seems that the low-light handling, sound quality and feature set will be loads better. So should I splash out the extra cash and go for the Sony, or is the JVC still going to be the better bet?
    Bear in mind that I don't care at all about the still-shot capability of either camera, as this is a feature I won't be using at all.
    Any input gratefully appreciated - especially if you've tried/owned both cams!
  2. Drafter
    Drafter
    I havn't tried either cam but if I could have a do over I'd save for a Sony or Canon.
    Drafter.
  3. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    Thanks.
    I've decided now, see my reply to the other thread I started! But you're right - the Sony's clearly the best.
  4. AAA
    AAA
    JVC 7 is a very good model, but can not be compared to Sony 120!......
    GO fo SONY 120 !!!!!
