Buying in the US.
Discussion in 'AV Receivers & Amplifiers' started by mandril, Aug 18, 2003.
  1. mandril
    mandril
    Jan 12, 2003
    174
    19
    Are there any high end amps/processors available in the states that would work equally good here?
    I've just been looking on the US ebay and theres loads of cheap stuff over there, Top quality brands aswell, no rubish!
    Ta Ricky:confused:
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    They should work fine but you'll likely need a step down transformer of some kind ( easy to find for about 30quid)
    Not sure if you might have a problem with a receiver on the tuner side of things but radio frequencies are radio frequencies I'd expect. RDS and channel ident info may not function though.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Some will be able to switch voltages (the parasound im told is an example).
    If you can get a particularly good buy it can be a very big saving, but id be wary of buying 2nd hand, its hard enough to do in this country letalone doing it internationally
    Ad
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    There's also the small issue of import duty,and sometimes warranty validity also...it often adds up to being almost the same cost as buying UK stock,certainly if a high current transformer is neeeded for some of the higher powered amps.
  5. thebfg
    thebfg
    beware, radio frequencies in the USA are different to ours. they transmit on the odd numbers so any station in the Uk transmitting on the even numbers will not be very clear.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You may have a problem with the radio side of things. Americans use a different channel spacing on AM, (I think it's 10kHz, where we use 9kHz), and on FM they use "even" frequencies where we use even and odd, so the tuner might go up in steps of .2 MHz and not .1 MHz.
    You will also have to pay import duty and 17.5% VAT when it arrives in the UK.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I am sure that Mandril will be pleased that this has been sorted out now, even though he asked his question (and was answered) in August 2003 :D
