Buying from U.S
Discussion in 'Blu-ray & DVD Players & Recorders' started by davyuk, Oct 29, 2004.
  1. davyuk
    davyuk
    Hi everyone. Could anyone tell me whether it is worth buying either a Tosh 32 or Panny 85 from across the pond. I have checked and even with delivery it is cheaper - but will everything still work ie. Videoplus. And what about the warrantee.
    Many thanksaroonies
    Davyuk
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    Don't do it! You won't have Scart connections, PAL recording, a UK compatible tuner or a compatible power supply. Not to mention it won't play Region 2 disks. Put you hand in your pocket and buy a UK model!
  3. davyuk
    davyuk
    Thanks you've talked me out of it. :thumbsup:
