Buying DV Camcorder - suggestions?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Saint4320, Feb 28, 2003.
  1. Saint4320
    Saint4320
    Hi all
    I want to buy a DV Camcorder and am looking for advice on which to buy really. Basically it doesn't need to have massive amounts of technology - just something that's easy to use, has good features and is small with good quality movie production.
    I am a particular fan of Sony stuff but don't necessarily have to buy a Sony machine if there's a better option. Budget is around £600.00.
    Thanks in advance.
    Saint
  2. Saint4320
    Saint4320
    Oh come on. Someone must have SOME advice!!
    Saint
  3. OGIII
    OGIII
    Stay away from Sony MicroMV.
    I'm going for a Panasonic GS1 at £399 but you can spend you're full wad on a higher model from same range.
    The new Pana range GS10 etc, seem to have been made smaller by reducing te CCD to 1/6 rather than 1/4 which to me suggests that low light and normal filming will be lower quality but who knows.
  4. EvilMudge
    EvilMudge
    OGIII,
    Check out Lets Go Digital for pretty much the best prices on official UK products from all the big manufacturers.
    They've got the GS3B for £449.
  5. OGIII
    OGIII
    Thanks Mark
    I got my Mum's GS1 from them for £399 but they don't seem to stock it anymore.
    The GS3 is at a great price but I don't think it warrants the extra £50, I can;t think of any time I;m likely to use the DV In.
    OG
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    If you ever intend to edit your videos on a PC then the DV-in could be invaluble. You could copy the project back to the camera as a high quality backup of the finished edit or copy an edited film back to camera and then play back to a DVD recorder at high quality.
    There are loads of reasons to have DV-in on your camcorder, none of which you intend to use at the moment but could be very handy in the future.
    Camcorders are not cheap and spending an extra £50 now could save you buying a new camcorder in the not too distant future.
    Mark.
