Buying an unlocked US mobile
Discussion in 'Mobile Phones Forum' started by Seth Gecko, Nov 17, 2004.
  1. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    I want to verify this if anyone can help me.
    I've seen a phone that's US only and network unlocked (I wish they'd call them sim-free like us!). Is there any consideration I should be aware of about buying such a handset.
    The charger isn't a problem - it's a Motorola phone - and I have 2 charger types from Motorola - the "Usual" type and the USB type with the V3.
    The phone is Tri band or Quad band - so no obvious issues there.
    I can't see any issue to obtaining the handset - but just to be sure, anyone wish to comment ?
    TIA
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Well in the US tri band could mean 850/1800/1900MHz in which case you would be able to use it on 900MHz networks such as Vodafone or O2 in the UK. Check exactly which frequencies the phone operates at. Also make sure it is a GSM phone as they do use some other systems in the US (which also use SIM cards)
