Buying an LCD major help needed
Discussion in 'LCD & LED LCD TVs Forum' started by Gortz, Dec 11, 2004.
Tags:
  1. Gortz
    Gortz
    Hello guys,
    You all seem pretty well informed and I have somewhere between little and no clue about LCD screens so here goes, can someone help me locate something capable of the following or give me a list of screens to check out:
    • I'm looking to buy an LCD screen for watching movies on
    • I won't be watching TV (don't have an arial or sky etc).
    • It MUST connect to my computer using DVI (I presume that'll give the best possible picture from a comp?) as this is what I'll be using to play the movies.
    • Not fussed about sound, already got a 5.1 setup sorted
    • I want it to be fairly big 28" up, ideally around 32" I think
    • I want to spend around £1000-£1500 (£2000 at the very most).
    • For my money I want the world... best possible picture, biggest screen size, highest resolution (I hear 1280 x 720 is best apparently?)
    • I'd prefer it to be wall mountable
    Can anyone help me, recommend some things please?
    Oh another thing, I was looking at a Sharp today that looked pretty good, it was on special I think at £1800ish, 32" aquous or something I think? Any ideas what its like, or what the model no is likely to be?
  2. Gortz
    Gortz
    Ok I've been doing some digging and these seem to be good, am I right?
    Samsung 323t 32in
    Sharp LC-32GA3E 32in
    The response time on the samsung seems to be 23ms on the samsung but I can't find one for the Sharp. My monitor is 25ms and it ghosts a little bit so I'm worried this might too!
  3. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    I have a Sharp LC-32GA3E and it's awesome. I highly recommend it.
    It's resolution is 1366x768, and has a response time of <16ms
  4. Gortz
    Gortz
    That sounds ideal, I'll have to see if I can find them in stock somewhere so I can get a demo. Does anyone know a good stockist where I can get a good price. The cheapest I've seen is £1299.
  5. jgrg
    jgrg
    Oct 19, 2004
    559
    28
    Cambridge
    +36
    Unfortunately they are in very short supply at the moment. The LC32GA3E may have been discontinued to be replaced by a new model, the LC32GA5E (without DVI), in the new year. We're not sure about the LC32GA4E - see other threads on this subject. I have an LC32GA4E on order and crossed fingers.
    James
  6. Gortz
    Gortz
    Just my luck! Is there anywhere that still has it?
  7. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Dunno, but you had better call around quickly. I had to phone about 15 different places before I could get hold of one over a week ago.
  8. Gortz
    Gortz
    :( gutted, I was hoping to wait until maybe February to buy the screen, looks like I might end up being skint right away if I have to get it now haha.
  9. Gortz
    Gortz
    Ok been looking a bit more, whats the difference between the Sharp LC32GA4E and the 3E? Seems to be more 4E's around and they seem to be similar prices, or am I going mad?
  10. jimg
    jimg
    Jul 4, 2004
    826
    +58
    The postion of the speakers! GA4E on the side of the screen and GA3E on the bottom. :smashin:
  11. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Yea, I had planned to wait until next year too, but didn't want to be stuck with a GA5. A GA4 is probably easier to get hold of, and is the same thing apart from speakers.
  12. djsat2
    djsat2
    Viewsonic N3000W, comes with PC drivers and is essentially a big glorified PC monitor. Has DVI (HDCP) aswell as about any other connector u can think of. The screen is about 30" (quoted as 32", casing). Pic qulity is good, i had one almost a month and love it, no dead pixels either. Sounds ok from speakers but as u said u got 5.1 alreayd setup. Has VGA in too and a VGA out. Two analogue TV tuners for PIP etc. and it cant do PIP between different connectors (been playing Xbox while having NTL TV in smaller window). 1280 x 720 and it cost my about 1350. Check it out.
