Buying An IPod From USA
Discussion in 'Headphones, Earphones & Portable Music' started by DaveH, Jan 9, 2004.
  1. DaveH
    DaveH
    Aug 1, 2000
    714
    Surbiton, Surrey
    +22
    Hi all,
    I thought I would bring this up seeing as the pound is so strong against the US dollar.
    If you bought an Ipod from America, what kind of guarantee would you get? Is it only for North America or will it be Worldwide.
    Also the charger will definitely be 110 volts, can we just buy a charger in the UK and will that work? Or will a transformer be required.
    Finally I think this is a really good idea if it is plausible due to the saving of money and the volume would not be restricted on the unit like the UK ones.
    Any thoughts?
    Thanks is advance.
  2. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    On the subject of chargers - you can always use your firewire port to charge the ipod that way you wont have voltage issues. Can't say I've ever used my charger, always charge it from my mac.
  3. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    on the 2nd gen ipods at least the charger was universal with a switchable socket - i think apple sold a worldwide pack for about 20 quid with a uk/european/us socket in it so if thats still the case its a non issue; or as tomson says you could use the firewire port. plus theres the option of buying a cheap 5 quid adaptor for US - UK (seen them in train stations and many other places)
    im not sure about the guarantee but it probably would only be restricted to the US which is a major pain if it breaks (ive rmaed my 2nd gen one twice in a year tho this one seems good now :D)
    the final issue is that unless your flying out to the US anyway and are planning to sneak one back then your gonna face import/custom duty charges which im sure will annihilate any previous savings you were making.
    still maybe worth a look - esp if you are travelling out there anyway
  4. DaveH
    DaveH
    Aug 1, 2000
    714
    Surbiton, Surrey
    +22
    Thanks guys.
