Buying amp from US
Discussion in 'AV Receivers & Amplifiers' started by hitz, Mar 28, 2005.
  1. hitz
    hitz
    Dec 18, 2001
    67
    Is it worth buying a receiver from the US. What sort of complications will i encounter bringing it back to use here (i.e warranty, power supply etc).
    I will be visiting the US (NY) - so their will be no problems in terms of shipping rate as I will pick it up myself. Also - their are several of us going so im sure between us all - we will not go over the duty/tax free allowance combined.
    Any suggestions
  2. Grimley
    Grimley
    Sep 19, 2003
    870
    Deepest, Darkest Essex, so BEWARE!
    +98
    IMO not worth the hassle -why?
    1. import duty & VAT charged by customs
    2. warranty not valid here
    3. voltage - 220V here 110V there so you'd need a lump of a step-up transformer to run it
    4. Shipping costs - add the VAT & import duty too & you'd've paid the same or more than would've done here
    my 1p's worth.... ;)
  3. Wolfman310
    Wolfman310
    Dec 12, 2004
    146
    +5
    From memory your allowed to have £140 of stuff to bring back in and then you have to declare it, if you don't and you get caught, you will have to pay, so is a bit of a risk
    Also, you can't combine your allowances, it has to be per person.
  4. Cliff
    Cliff
    Mar 17, 2001
    4,688
    137
    Kent & overseas
    +1,836
    Apart from the duty issue- make sure you can switch it to 230 volts. Remember you probably won't get a receiver with RDS- Also make sure the FM and AM frequency interval can be switched.
    If it has on screen setup graphics they will probably be NTSC only.
    Ask for a "General model" rather than a US model as these have more switched options.
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    22,934
    The Fylde Coast
    +11,885
    Denon told me that their US receivers are not "designed" to work with European tuner frequency steps. Bit of a hit and miss whether you get yoiur UK FM stations or not.
