Buying AE-100 from Germany!!!!!
Discussion in 'Projectors, Screens & Video Processors' started by Kramer, Mar 25, 2002.
  1. Kramer
    Kramer
    I received my AE-100 from
    hificomponents.de
    this morning. Unfortunately complete with an open blue pixel in the top right hand corner. The surrounding pixels are also badly tinged with blue, resulting in a bright spot approx 4 pixels in area.
    I've e-mailed the Germans asking for a replacement, & received the following reply:
    Hello Mr. *****
    Unfortunately it is normal two have 1 – 3 pixel.
    We do not replace it.
    Best regards
    Julia Widmann
    Luckily, I have a good friend here who will organise a replacement unit, but anyone comtemplating a purchase from this company had better beware
    :mad:
    I'll contact them again & REJECT the product. I'll post again regarding the outcome, but take care:eek:
    YOU have been warned:devil:
  2. Timh
    Timh
    Sep 14, 2000
    5,223
    3
    3
    Altair-4
    +310
    Kramer
    :( sound's bad, are you sure it isn't dust, it's just I have never heard of a stuck open pixel bleading into the surrounding pixel's :confused:
    I guess your not in much of a mood for testing the Nintaus then?
    good luck
