I'm fond of saying -
You can't get what you want until you know what you want.
By that I mean, you have to understand what you want for
budget, power, and features, then seek out amps that meet those goals.
The Arcam is a nice amp and that package is also very nice ...assuming... it does what you need done. The Arcam is 50w/ch, it appears to have 1xOptical and 2xCoaxial connections so it has a DAC, and while it does have a Network Connection, it is not clear if it has Network Streaming. It also has a Phono Input and Pre-Amp outputs. (~£700)
50w/ch is sort of low, but for most people for most music at most volumes that is fine. I went through my Party Years with a 45w/ch Pioneer.
I believe the
Monitor Audio Silver 100 are 8" speakers, so they should kick pretty well for bookshelf speakers. (£650/pr, 40hz, 8").
So, that combination can't be faulted, assuming it does what you need done. And given that the total individual prices are (£699 + £649 = £1348), the £1049 price is certainly appealing.
But taking a completely different approach is this bundle - (£1169) -
Yamaha R-N803D Monitor Audio Silver 100
petertyson.co.uk
Same speakers, Monitor Audio Silver 100, but with the
Yamaha RN803 Network Receiver. The RN803 has
100w/ch, DAB/DAB+, Network Streaming, DAC, Room-EQ, Full Bass Management, Phono In, Sub-Out, and so on.
So, more Power and a much more expanded feature set. Just trying to illustrate the contrast in various systems.
Are you set on Bookshelf Speakers or would you consider Floorstanding?
Here are a range of Yamaha Bundles -
Peter Tyson Audio Visual Online - Hi-Fi and AV retailers.
petertyson.co.uk
Good Yamaha Amps in your price range are the AS701, AS801, and the RN803 Network Receiver.
But, all that said, I can't fault the original choice, but make sure it does what you need done.
One tiny thing that may not matter to you, but it does to me -
Tone Controls - the Arcam does not appear to have them, though the Yamaha does. So, again, think about the features you want and need.
Repeating myself, I can't fault the
Arcam/Monitor Audio bundle, and a nice +£300 discount certainly doesn't hurt.
Is your budget pretty much locked at around £1000, or is there some flexibility there?
If you can go as high as £1400, and the Arcam/Monitor Audio appeal to you, you might want to consider the
80w/ch Arcam SA20 - (£1399 bundle) -
(some say 90w/ch to 8 ohms) -
A package comprising the Arcam SA20 ampllifier and the Monitor Audio Silver 100 speakers.
www.sevenoakssoundandvision.co.uk
The design of the HDA range draws upon all of Arcam’s experience as one of the UK’s most respected audio companies, to produce Arcam&rs...
www.arcam.co.uk
I will always go for more power if I can get it. But that is purely up to you and your wallet.
Personally, I like the Yamaha RN803
- more power, more features - but that doesn't mean I don't see the appeal of the Arcam SA10/SA20 to other people.
If you really don't have a problem spending more money, the SA20/Silver 100 would be preferred.
Just a few thoughts.
Steve/bluewizard
