mogamal
I'm torn between sony KD49XF8577 (679£) and sony KD49XF8796BU (669£) at currys, and I can't find a major difference, some websites says they are VA panel and others says it's IPS.
another option is buying Refurbished Samsung QE49Q6FN (599£) from Richersounds with only 12 months warranty.
Sony panels in stores seemed to be way better than Samsung (sony xf8577/xf8796 vs samsung nu8000/nu8070 for example)
for me viewing angles are not a main concern as I'll be sitting directly in front of the TV.
for usage I'll use it mainly for IPTV stream, watching movies from my external Hard disk and maybe PS4 Pro and Netflex in future.
I'm already stretching my budget with 680£ so I can't go up to higher models.
Thanks in advance, it would be helpful if I decided today.
