buying advice seperates
Discussion in 'AV Receivers & Amplifiers' started by dondotcom, Oct 20, 2004.
  1. dondotcom
    dondotcom
    Help!
    looking to purchase surround sound system for the first time.
    so much info it gets confusing.
    initial thoughts are as follows
    marantz sr5400 AMP
    tannoy fx 5.1 speakers
    cambridge azure 540D DVD
    thoughts and opinions would be much appreciated as my
    knowledge is limited ( this may already be obvious ) !
    in anticipation
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    :hiya: Dondotcam and welcome to the forums
    The choices are quite a good base for a H/C setup. :thumbsup:
    I would suggest also look at the Pioneer dv575 as it has good reviews on here and can play anything you can throw at it:) and its cheaper than the Azur.
    http://www.richersounds.sv01.net/index.php?f=itemdetl.php&p=302301
    Ive also found the Tannoys for £159 + and extra £30 if you want the stands + postage
    http://www.stoneaudio.co.uk/?goto=h...asp?ManufacturerID=302&openNode=MANUFACTURERS
    I dont know how much your looking to pay for the 5400 (cant find a price on RS website) The cheapest I can find it else where is £199 from
    www.petertyson.co.uk
    I have bought from them and can highly recommend buying from them:D
    If you can stretch to the upgraded OSE model its only £269:smashin:
    Review.
    http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=4568
    Dont forget to keep some budget for some better interconnects. Good budget coax (for digital sound to the amp from the dvd player) is the Profigold PDG481
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32833&item=5726723639&rd=1
    Also a good analogue interconnect for listening to cd's from the dvd player. Its short (0.5m) so good if they are going to be close together. Good cable and a bargain from ebay (i have a couple from the guy.:smashin: )
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32833&item=5726778834&rd=1
    Richer sounds price and details.
    http://www.richersounds.com/index.p...10&PHPSESSID=ba833f646e3feb827a34d32942b83230:eek:
    Hope this helps and doesnt confuse :D Welcome to this very expensive and enjoyable pastime.
