Buying advice please. Need component/dvi for projector.
Discussion in 'Blu-ray & DVD Players & Recorders' started by mrflibble, Mar 19, 2005.
  1. mrflibble
    mrflibble
    Hi folks.
    I hope you'll be able to help me.
    I've just purchased the Optoma Themescene H30A projector online and want to buy a new DVD player to source it.
    My current DVD player (Sony DVP-NS905) doesn't have component or DVI outputs which is what I want for the projector.
    Can anyone recommend a decent DVD player for about £250 that has either of these outputs?
    I've been reading about the Denon 1910 but am unsure of whether to go for the replacement Sony player for mine (the DVP-NS955 or soon the NS975 with HDMI).
    I was also tempted to skint myself and go for a pricier model like the Denon 2910, is the jump from £250 to £500+ worth it do you think?
    Also I'd like opinions on whether to go with a long component cable or use a long DVI cable to the projector. Can I expect similar picture quality with both?
    Any recommendations on cables would be handy as well ;).
    Thanks very much in advance!
    Kind Regards,
    Flib.
  2. mrflibble
    mrflibble
    Hey folks.
    Well I'm an impatient bloke, so I've gone and ordered an Denon DVD 2910 with some cables. An s-video for the couple of months before I move house, and a cheap dvi to dvi cable (from keene.co.uk).
    I'm not sure whether this cheap dvi cable will be good enough or whether to get a decent (and very long) dvi to dvi cable, or go the component route (any advice would be appreciated).
    Regards,
    Flib.
