Buying advice needed
Discussion in 'Photography Forums' started by onefivenine, Jun 11, 2005.
  1. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    Hello,
    I've got an EOS50E with 28-80mm and 75-300mm lenses.
    I'd like to upgrade to an EOS20D body. Will my old lenses be suitable?
    Any advice appreciated!
  2. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    All EF lenses fit the 20D
  3. witters
    witters
    Jul 13, 2000
    11,991
    Yorkshire
    +264
    Just remember the 1.6 crop factor. i.e. 28-80 becomes a 45-128....
  4. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    Does the 1.6 crop factor only apply to the old EF lenses?
  5. witters
    witters
    Jul 13, 2000
    11,991
    Yorkshire
    +264
    No. It's the sensor in the camera which dictates the 1.6 crop factor and not the lens.
  6. homerdog
    homerdog
    Mar 7, 2003
    212
    28
    Sussex
    +36
    No, it applies to all EF and EF-S lenses on a 20D
  7. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    Thanks for the help guys.
    Does the 20D's in-built features replace the need to use colour correction and graduated filters?
  8. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    It does have built in filters, and you can change the colour temp ect you can bracket the WB.
  9. witters
    witters
    Jul 13, 2000
    11,991
    Yorkshire
    +264
    You still need grads to preserve details in sky's etc...
  10. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    I take it you still need to use filters for graduated effects.
    I'm tempted to buy a 20D body only and a EF-S 10-22mm lens to go alongside my 28-80mm and 75-300mm. This leaves an obvious gap between the 35mm equivalent of 35-45mm... but is it likely to be an issue?
  11. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    Yeah i'm sorry, the built in filters are for B&W , as tony said you'll need polarizing filters ect for certain conditions
  12. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    No issue there that i can see
    personally i'd not go for the efs range as they wont fit the full frame digital canons that i hope one day to have, and the apertures too small for me and i always think about the resale value/cost, which is close to the 17-40 F4L. But many people love that lens
  13. homerdog
    homerdog
    Mar 7, 2003
    212
    28
    Sussex
    +36
    Good idea, it's what I'd do in your position :)
