Apologies in advance for yet another 50-55" thread. I recently purchased a Philips 50PUS7805 to replace an old Panasonic plasma TV and ended up returning it. I get that it's low tier but, no matter how much I calibrated, I just couldn't get a decent picture out of it. Everything looked faded and washed out. There was other stuff too - the Saphi OS was very limited and the Alexa integration clapped out after 24 hours. So I now have credit with Richer Sounds and am trying to decide on my next move.
Here's what I will use the TV for -
It's a secondary TV for the attic so primarily watching sports and playing previous gen consoles (Xbox One / Switch). That's not to say that a next gen isn't on the horizon, just not for the foreseeable future.
General TV viewing. I have satellite and antenna cables in the attic, but I don't have a dedicated Freesat box.
I'll also occasionally use it for Netflix / HBO Max / Prime Video.
Have a sound bar so audio not that important.
In terms of the environment -
The room is bright during the day because of the Velux windows and reasonably dark in the evenings. I mostly use it during the evenings.
I sit around 8 feet away from the TV. There's a two seater sofa and no other viewing positions.
The space will take a 55" unit but 65" would be too big.
I have an OLED downstairs (a Panny FZ802) which I adore. To be honest it's spoiled me. I can't afford to go OLED so I reckon I'm looking for a VA panel - narrow viewing angle and deeper blacks sounds like the best fit for me.
If I wanted to stay on budget the Hisense U7Q at £550 sounds like a decent replacement with better colour and brightness but it seems to have serious motion issues which would be a deal breaker. The U8 isn't an option because they don't stock it.
They also have a Panasonic TX50HX800B in their clearance section for £580. I'm generally a big fan of Panasonic and it seems like a good price. It gets decent reviews but seems to have brightness issues.
Other options are the Samsung QE50Q60T for £630 which seems like a nice TV but only 60Hz panel.
If I blow my budget I can start looking at the Sonys. I could definitely stretch to £750 for the Sony KD49XH8505BU. I like the basic specs - Twin Tuners, Android TV (I own a Shield so well used to the interface), 100Hz panel - but I'm struggling to find any reviews on it. Is it £120 better than the Samsung?
The XH9505 at £900 sounds amazing but it's a lot of wedge.
So, bit of a ramble there but would welcome any advice, opinions or experience of any of the above TVs.
Thanks for reading.
Thanks for reading.
