Promoted Buying a PC? We Make It Easy
Cyberpower UK
AVForums Sponsor
Here at Cyberpower PC we have a PC for everyone. We are one of the biggest PC manufacturers in the UK. Looking for a gift for yourself or looking for a gift for a loved one, we will have the system for you.
Whether you are shopping for a dedicated gamer, an aspiring streamer, a devoted content creator, or even just a PC for home use, our team of experts will use their years of industry experience and knowledge to ensure you purchase the perfect PC for you or your loved one.
We work with the best component manufacturers in the game from Nvidia, Intel and AMD and we are proud to say we are only one of five launch partners in the UK for these top brands. This means we are first to market new products, and the savings we get on price are handed down directly to our customers. We pride ourselves on the choice of components we stock, which means we can build your PC to your exact needs and budget.
Buying a PC for the first time, or buying for someone else, can be quite daunting, but we have helpful tools to help you along the way. We make the process of buying a PC easy! Take a look, and remember if you need anything further, get in contact.
Cyberpower PC Buying Guide
Our Cyberpower UK PC Buying Guide is a permanent fixture on our website. This guide will help you every step of the way. From understanding the different PC components to exploring our range of systems, to even learning how to use our website's configurator. By the time you purchase a new system, you'll know exactly what goes into it.
The PC Buying Guide is here for you, whether you are:
  1. New to PC Gaming and need to know more about components before spec’ing up a gaming pc for the first time.
  2. Buying for a loved one and have no idea where to start
The PC Buying Guide takes you through the buying process step by step from helping you understand the components needed to build a PC to the aftercare we offer. We are proud of this PC Buying Guide and our customers have found it extremely helpful. However, if you still need help, our expert sales team are on hand to help you out, on the phone, via email or through our Discord channel.
Build My PC Tool
We have created a Build My PC tool designed to guide you to your best option PC based on your needs and budget. It’s simple. You pick your budget, make a few simple choices about the system you want, for example, whether you need a desktop or laptop, which brands you like best and whether you need the PC the next day or can wait for a custom-built PC.
We then use this information and offer up a selection of PCs that meet your criteria. You can then alter the spec if you want to (custom build only) or take the PC direct to the shopping cart to purchase. It’s as simple as that!
Our Configuration Tool
Our configurator is simple to use, but we understand it can be quite overwhelming if you haven’t bought a custom-built PC before. Check out this video guide on how to use our website configurator, and it will tell you everything you need to know.
Things to Consider before purchasing
When buying a new PC, there are a few things to consider, whether you are buying it as a gift for someone else or a treat for yourself.
  1. What are you using the system for? Gaming PCs, for instance, require a graphics card to play the most popular titles of today, whereas a PC built for home use will not need this component. Once you know what the PC will be used for, our informative website will help you in the right direction.
  2. Will you need add-ons? A PC is one part of a full set up but for the PC to work, you will need a monitor, keyboard and mouse. Have you already got these or will you need to purchase these too? We have a Gear Store which is stocked full of a selection of peripherals to get you fully set up, or you can add peripherals using the Accessories section of our PC configuration tool.
  3. Do you need the PC on a particular date? Our custom PCs can take between 8-14 days to build and ship, so you need to be conscious of timings if you are buying a PC gift for a special occasion or need the PC for a specific date. We do have Next Day options for those who need a PC quickly or don’t want to wait. Our Next Day options have been designed in-house by our team to suit a range of needs and budgets.
The Cyberpower Process
Our process is simple! Once you have the PC you want to buy, we will build it, test it and deliver it to your doorstep with minimum fuss, so all you need to do is sit back, relax and wait for our courier to deliver your new system. If you need anything throughout the buying process or after you have received your PC, the team are here to help you out.
One Last Thing
As mentioned, Cyberpower UK has a PC for everyone. Don’t just take our word for it. Have a look at the wide range of systems we stock. If you see something you like, then visit the Cyberpower UK website to find out more.
Our PC Ranges
Our Laptop Ranges
