P
paul
hi there,
i currently have a DVD player on my PC only, and want to get a player for my TV, but most of my discs are R1, so I need a multiregion one.
i have been looking at techtronics and narrowed the choice down to panasonic rv31ebs (has their top level upgrade) and the toshiba SD-210e. i have heard good things about the toshiba, but i am just concerned because according to techtronics website, with their upgrade it will output in NTSC, whereas the panasonic can do PAL60...
i know my TV can handle NTSC videos, but i don't know if this means it is PAL60 or true NTSC compatible - it is second hand and probably a few years old.
i have been trying to get techtronics on the phone to explain whether the toshiba will output PAL60 or not and surprise surprise I have still not got through to anyone despite being on hold for over 20 mins...
now i've seen a Yelo DVD800 player which is supposed to be very good and is multiregion compliant without upgrading - does anyone know if this player outputs NTSC or PAL60, and can it handle RCE? i cant seem to find much info on it.
don't know which one to go for! does anyone upgrade the toshiba 210e so it outputs in PAL60 and is able to play RCEs?
cheers paul
cheers paul
