Buying A HDTV
Discussion in 'General TV Discussions Forum' started by RichIbizaSport, Mar 23, 2006.
  1. RichIbizaSport
    RichIbizaSport
    Mar 20, 2006
    30
    Hull
    Hi guys. Im looking at buying one of these:
    http://www.consumer.philips.com/con...&proxybuster=KCEJTRNM3GNQHJ0RMRCSHQVHKFSESI5P
    The only thing is i'll be buying it second hand (I dont have too much money!) and according to the seller the speakers dont work, he assumes its a faulty capacitor.
    I would like to use it for wathcing tv and running an xbox 360.
    Im also looking to buy a 5.1 sound system, with atleast an optical input (for the xbox 360). So i know i can have sound for the xbox. But the question is can i have sound for watching tv?
    If you've looked at the link above the specification for connectivity is:
    Connectivity
    Ext 1 Scart : Audio L/R, CVBS in/out, RGB
    Ext 2 Scart : Audio L/R, CVBS in/out, S video in
    Other connections : Antenna IEC75
    Front / Side connections : CVBS in, Headphone out, S-Video in, Audio L/R in
    AV 3 : DVI-I with HDCP, Audio-in mini jack 3.5mm
    Number of scarts : 2
    Forgive me for being not too technically minded, but can i connect speakers upto the tv? As i dont see and audio out?
    Many thanks
    Rich
  2. the porter
    the porter
    Dec 15, 2004
    5,848
    lancs
    +1,593
    i cant see a hdmi input on it are you sure its hd ready, regarding speakers just connect a 5.1 system by scart to the tv turn off your internal tv speakers job done!!
  3. RichIbizaSport
    RichIbizaSport
    Mar 20, 2006
    30
    Hull
    26" LCD HD ready flat TV Crystal Clear III - i think that sort of gives it away? or is this information incorrect?
    i thought the AV 3 : DVI-I with HDCP was something to do with it?
    as for the speakers. does anyone know of any 5.1 speaker systems that have an input for optical (xbox 360) and a scart socket (tv) ?
    cheers
