buying a camera
Discussion in 'Photography Forums' started by que, Aug 28, 2005.
  1. que
    que
    Aug 28, 2005
    2
    hi,
    does anyone know what digital camera takes good photos in dark conditions, such as gigs.i would be grateful for any replies before i decide which to buy,
    thanks.
  2. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    how much are you willing to spend?
    many compacts struggle in low light through noise and not being great wide open.
    i shoot alot of gigs and eventually resorted to a DSLR, however some of the better compacts will do the job, look at the olympus C8080? something like that, its got a good max apature (f1.8) and is quite a good camere so im told
    good luck :)
    im sure others will be better at recommending than me!
  3. que
    que
    Aug 28, 2005
    2
    hi,
    thanks, i will have a look,i just wanted the opinions from people who know more than me. :confused:
  4. alastair
    alastair
    May 11, 2004
    53
    Northumberland/York
    I have heard good reports about the Fuji F10 with usable images at ISO 1600, no personal experience but have a look at www.steves-digicams.com and www.dpreview.com for reviews and ISO comparisons in low light.
  5. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    You will probably want a DSLR inorder to capture the action with out any lag - with a DSLR you can then get a fast lens such as a F1.8 lens.
    whats your budget
