Buying a 55" & a 40", are these ok?
Discussion in 'What Is The Best TV For You?' started by eireann10, Nov 23, 2017.
Tags:
  1. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    Was originally going to buy the Sony XE90 bundle, but now think that might have been overkill for me anyhow
    i need a 55" TV for the main living room which has mostly normal TV (alot of Sport) and some gaming
    I also need a Approx 40" for the boys which will be nearly all gaming (xbox one)
    Im thinking of the two below TV's, saw recommendations on here for the 55" but am unsure about the 40" for gaming (doesnt have to be 40" but dont want to spend to much on it)
    Buy Samsung UE55MU7000 HDR 1000 4K Ultra HD Smart TV, 55" with TVPlus/Freesat HD, Dynamic Crystal Colour + HW-M360 Sound Bar & Subwoofer | John Lewis
    Buy Samsung UE40MU6120 HDR 4K Ultra HD Smart TV, 40" with TVPlus, Black | John Lewis
  2. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    Think im set on the MU7000, just not sure if the MU6120 would be any good for gaming, both boys dont have great eyesight, both where glasses.
    Anyone any thoughts/reviews?
  3. Dodgexander
    Dodgexander
    May 29, 2007
    14,877
    +4,339
    Those are both good choices for your respected uses. The main drawback to both TVs are the narrow viewing angles.
    Samsung MU7000 is a good buy at the moment having recently been reduced however you may not need a TV with a 120hz panel unless you are one to use motion enhancements to smooth out the judder and blur in sports.
  4. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    MU7000 is out of stock in JL
    THinking of the Samsung UE55MU6400 with soundbar bundle
    Any thoughts anyone
  5. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    after all that i went for the Panasonic 58EX700B + Panny Soundbar(extra) from JL & 2 Samsung UE40MU6120's
  6. masterc34
    masterc34
    Nov 24, 2016
    98
    11
    Aberdeen, Scotland, UK
    +15
    Hello mate, any review on the Panasonic? I am thinking of one as well, and like you i had wanted the Samsung which is now out of stock :-(
  7. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    Hi, i only ordered it this morning
    Im the type that reads and reads and still doesnt have a clue and ends up buying nothing, so just bit the bullet before my head went.
  8. masterc34
    masterc34
    Nov 24, 2016
    98
    11
    +15
    Oh okay mate, many thanks. It seems like we are the same. I spent weeks here last year reading about the Samsung UE55KS7000 until they all went, still didn't buy :-(
  9. ChrisKz
    ChrisKz
    Nov 13, 2016
    496
    46
    UK
    +138
    I bought the Panny 58 also this morning , good price and will do as a stop gap. Reviews weren't that bad , so bit the bullet
  10. ChrisKz
    ChrisKz
    Nov 13, 2016
    496
    46
    UK
    +138
    JL showing NO STOCK . looks like another sell out
  11. Dodgexander
    Dodgexander
    May 29, 2007
    14,877
    +4,339
    Glad you didn't get the 55" MU6400
  12. eireann10
    eireann10
    Oct 15, 2007
    2,907
    N Ireland
    +560
    well as you know i went for the Panasonic 58EX700B which took a couple of weeks to arrive, i havent had time to mount it so its still sitting in the box.
    After reading the 700B thread im not sure if i should take it out of the box, im thinking of returning it.
    Any recommendations considering my first post, id watch plenty of Soccer, Hurling etc and films/TV through IPTV Zgemma box. I can go upto around £1000
    Or should i just stick with the Panny. :confused: :confused:
  13. Dodgexander
    Dodgexander
    May 29, 2007
    14,877
    +4,339
    I think anyone feels like that when they read any owners thread, not just that one.
    IPTV is generally poor quality compared to normal broadcast TV and on an UHD TV you're going to see the worst of it, you need higher quality sources if you want these to look good.
    From a motion perspective if you went up to models like the Samsung 55MU7000 or Sony XE85xx series you will only do better if you use motion enhancements in the TVs settings, out of the box these TVs (and any LCD for that matter) will perform about on par with the EX700..so its only really beneficial if you plan on utilising these settings. Since you're using IPTV, and probably outputting a fixed 50hz, I'd say its probably not.
