Buying a 16:9 screen in the UK
Discussion in 'Projectors, Screens & Video Processors' started by Timh, Jan 21, 2002.
  1. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Most of us have an idea of the projector we want, well I do, it's the Panasonic PT-AE100 16:9 projector.
    I need a 16:9 pulldown screen in matt white about 1 Gain.
    http://www.direkt2u.co.uk/ do a 203cm X 114cm 16:9 screen for £212, but this maybe a little big for this projector, the reason being that I may see the pixel structure from my seating possion of 3 metres. The question is, does anyone know of another UK supplier which supplys 16:9 budget screens at a slightly smaller size.
    Or should I go for a 4:3 screen like the model b 196 X 145cm from direkt2u.
    Thanks for any advice.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Most screen manufacturers will do any size or aspect ratio you wish. I have supplied Draper manual pull down screens in the ratio you are after. Obvioucly custom screens take a little longer to get than standard size ones.
    If you need pricing email me with dimensions you are after.
    Gordon
  3. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    Also, give Direkt2u a ring (number on their site) they will supply ANY size screen you wish (modified from another screen size by Da-lite themselves).
    Very good prices, knowledgeable and friendly. I'd recommend them.
    Regards,
    Ian Guinan
  4. The Boogerman
    The Boogerman
    Dec 22, 2001
    39
    Bavaria
    Tim, I'm in a similar position to you, in that I'm itching to get a projector (Panasonic looking top choice too), and have faced the dilemma of what screen to buy. I decided on a 4:3 Matt screen (80"x60" or 203x152cm) because I'll be watching movies (recent 1:2.35, 1:1.85 and older 4:3 ratios), TV and Music DVDs, plus TV and PS2. For me a 4:3 screen gives more flexibility and a larger 4:3 image. Having just spent a weekend enjoying a projector (Sony CX2) for he first time (kindly lent by a friend who uses it for work presentations and finally gave in to my constant pestering - hope to post my first impressions tomorrow). A 2m wide screen is not a bad thing at all - films look fab at this scale, though watching THe Simpsons at 100" diagonal was too large even for me. :)
  5. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Boogerman,
    Dont forget the Panasonic will do 4:3 inside a 16:9 screen.
    I think it will also stretch a 4:3 image like a widescreen tv does.
    I think it's important to get the pj first and then way up which screen to get after.
